ok.
so when you said this earlier...in response to my description of 500 pulses per revolution.
"I think that is correct. Post quadrature that would probably be 2000 counts/rev...."
Sorry if I am being slow here, I'm just trying to understand the logic so I can purchase wisely for my build.
In addition to understanding the math, I would like to understand what using an 3rd party adapter will do.
I now understand that converting single ended to differential does not increase resolution... Do the 3rd party converters that you reference in the FAQ page about going from single to differential signals simply allow the inputs on the Kanalog to be used... I suspect that the noise resistance of the differential signals is only there if the encoder is truly a differential encoder... not just a single ended that has been "converted" through a cheap adapter.
